Repair and disassembly information for Logitech's all-in-one Slim Folio case and keyboard. Compatible with iPad (5th, 6th, 7th, 8th and 9th gen) or iPad Air (3rd gen).
14вопросов Показать все
After putting in new battery’s the keyboard still won’t turn on
I replaced the old battery’s and my keyboard still wont turn on
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If replacing the batteries did not resolve the issue with your Logitech Slim Folio keyboard, here are some additional steps you can try:
  1. Check the battery orientation: Make sure that the batteries are installed correctly in the battery compartment. The positive and negative terminals should be aligned correctly.
  2. Check the power switch: Make sure that the power switch is turned on. It should be in the "on" position to activate the keyboard.
  3. Reset the keyboard: Try resetting the keyboard by turning it off, removing the batteries, and holding down the power button for 5-10 seconds. Then reinsert the batteries and turn the keyboard back on.
  4. Check the connection: Make sure that the keyboard is properly connected to your iPad or iPad Air. If it is not paired or connected, the keyboard will not work.
  5. Update the firmware: Make sure that your keyboard is running the latest firmware. You can check for updates using the Logitech Options software on your computer.
If none of these steps resolve the issue, there may be a hardware problem with the keyboard. In that case, it may be necessary to contact Logitech customer support for further assistance or to arrange for a repair or replacement.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
Both the battery change and the answer I found here were exceedingly helpful. I so appreciate clear instruction and being able to do this myself!
из
Sorry, the Slim Folio has no power switch. It has 2 CR2032 batteries. No way that I can see to "reset" it except to take batteries out and leave them out for a bit.
из
Same issue with Robert... No power switch. It's just a power button at the right top corner. Try to press and hold the power button for 5 to 10 seconds and it still doesn't work.
из
Seems to be a technobabble AI generated answer that is hallucinating about what it does not know.
из
Добавьте свой ответ
Katerina Rigan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 77
За последние 30 дней: 361
За всё время: 2,894
