Why did the LED behavior of the case change?
I've had these head phones for a few months now, and suddenly the LED behavior of the case changed.
First, when charging it (fully), or putting the ear pieces in, it just showed red anymore, where as it should show green. (Head phones still charge in the case, also when its not connected to a power outlet.)
The next day, the LED of the case wouldn't work anymore at all. No matter what I tried (e.g. factory resetting by 2 times tapping and then a third tap + holding for a few seconds).
I downloaded the JBL headphone app hoping, there would be a software update, but that app doesn't support this model.
Is there something else I could try or just live with the fact, that with JBL products under 100€ I'll be constantly running back to the shop? (Had the JBL Tune 215BT 2 times before, but the rubber cover that goes into the ear always came off after a year of using. Tried to glue it back together, but that didn't work very well.)
Update: The in ears wont load anymore, and so it seems something must be wrong with the power supply to the case. The female connector seems pretty clean to me, but I will try to clean it with flatter carved wooden toothpicks. The cable can't be the problem because we load our phones with it.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Выбранное решение
Looks like something is very wrong with the case
Был ли этот ответ полезен?
Оценка 0
I had to use an alternative battery like a phone charger with USB while it's plugged up. Try to see if you can get your earbuds to flash the three lights showing that it's charging let it charge for a little bit and it might actually still charge. I haven't found any other source but this forum speaking about the vibe 300 tws series. I kinda gotta baby it until I can find a replace case. Which is apparently on Amazon go figure. But still jbl did good on the quality of sound for the price.
Оценка 0
2 Комментариев:
I had this issue a couple times where the case wouldn't take a charge, I took the case apart and wiggled the battery connector around, works fine since, I did drop mine before it messed up tho so I probably knocked a connection loose
из
I had a different problem which I thought I'd highlight here. Whenever I charged the case, the light was permanently on red and the headphones weren't getting charged. I opened the case, assuming that the battery needed replacing. Battery was showing 3.2v but also only showing 3.2v when the case was plugged into USB C. This was plugged into an almost new iPad charger. I was suspicious of the low voltage and decided to try the original JBL cable which showed 3.8v across the battery terminals. The case is now charged and charging the earbuds. Clearly the case (possibly the voltage regulator) is fussy about the cable or the available power and won't charge. Hope this helps someone.
из
Добавьте свой ответ
Andrea's Repairs будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 7
За последние 7 дней: 21
За последние 30 дней: 83
За всё время: 2,822
