5v and 12v power source seach
searching for a spot of motherboard to pull 5v power and a 12v power plus also a 5v thats only active when computer on. long story short. accident happen around kids and i wont let a good machine turn to e-waste. PLZ help
Это хороший вопрос?
Оценка 0
3 Комментариев:
@caspersmith " to pull 5v power and a 12v power" what are you trying to drive with that power? What is it exactly that you are trying to accomplish?
из
@oldturkey03
I was wondering that also but going along with it, if the LA-F601P schematic could be found or purchased (I couldn't find it - perhaps your manuals sourcing magic can ;-) it should be easy enough to find suitable take off points on the motherboard.
Cheers
из
@jayeff apparently LA-F601P is not available anywhere,yet.
из
Добавить комментарий
Ответов (1)
i don't know what are you trying to do but, usually there is two inductor that outputting 5v and 3v, you can start from there.
as for 12v i think its a voltage coming from the battery and for the 5v that only active when the computer on means that its a 5VS rails, its a normal thing.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Casper Smith будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 95
