The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
396вопросов Показать все
Console not syncing wired or wirelessly.
I have the issue with my console being completely unable to sync up with controllers. the sync button does nothing and all I get when plugging in with a usb cable is a vibration but sill can't connect.
The sync button is supposed to make the xbox logo blink on the console power button but that's only a sign things aren't working as they're supposed to. Can't hard reset as power button is broken and have to insert/eject a disc to start up the system.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
First, make sure you have everything pluged in. Second make sure there is no damage.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
What needs to be connected? Damage to what? You need to specify things like this in your answers, otherwise, they don't help the OP.
из
@guardian10 I have no pictures to work with also the person should make sure every single cord has a match and the damage he or she should be looking for is static and burn marks.
из
Добавьте свой ответ
HonestySyndrome будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 32
