The Sony Bravia KLV-46X200A is a flatscreen TV in Sony's Bravia series.
Can I get the screen pliz
Can i get the screen pliz
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
replacement screens cost nearly as much as a new tv
Был ли этот ответ полезен?
Оценка 1
@erickkariuki It will be very difficult to find a new display. Even if it can be found it will most likely cost more than a new TV. You can always do an online search for a replacement but do not search by your TV model alone. Remove the back of your TV and check the label on the back of the LCD. It will have the manufacturer as well as the LCD panel number. Use that for your search. The only other thing you can try is to find the same model as your TV but broken other than the panel. Then harvest the panel from that TV.
Оценка 1
Добавьте свой ответ
Erick Kariuki будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 98
