Следующей моделью в линейке после iPhone XS, выпущенной 20 сентября 2019 года, стал iPhone 11 Pro. Он получил 5,8-дюймовый OLED-дисплей, тройную основную камеру и увеличенное время автономной работы.
Вопросов 20 Показать все
What do I need to do with these parts
Just wondering if I need to solder these together or if there’s something else I need to do
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Yes. This little board houses the charging mechanism for the iPhone 11 Pro and Pro Max. It's curiously the only model that does this. But that's where the actual charging chip lives on these models, rather than the main logic board itself.
You should be able to solder the charging board onto the new flex. Obviously be cautious, it is a dual layer board, just like the main board in the 11 Pro and Pro Max and soldering onto flexes takes some practice. But that's all that should need to be done.
Был ли этот ответ полезен?
Оценка 2
Hi
Unfortunately it appears that the solder joints have failed on your cable and you will need to replace it
Even if all the solder pads were still there chances are you would end up melting the cable so your best bet is to just replace it:-)
Hopefully this helps
Any questions please ask
Оценка 1
4 Комментариев:
Hi this is a replacement part that I bought online but It didn’t come with that top part from the photo. So I took it off the old charging flex cable part
из
@ikehardman21762
I’m that case you will probably have to reball the little square piece and hot air it into place
из
What do you mean by reball
из
@ikehardman21762
Reballing is a soldering term
It means to solder on new solder balls onto the chip or board so it can be reattached to a board or cable using hot air
If you look up solderballs on eBay you can order them from a verity of suppliers
I recommend mechanic
из
Добавьте свой ответ
Ike Hardman будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 126
