The Galaxy Note10 Lite was released in January 2020. It is a mid-range variant of the Note 10.
16вопросов Показать все
I replaced the charger board, and it is useless
This phone does not charge It doesn't even show me the charger sign. I took the phone apart and installed it again. It shows me the charger sign now but it is not charging I hope you will answer me. Is it possible that the problem is from the motherboard?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@lina11 absolutely possible. Check the Samsung Flow chart for this
Now I do not have a searchable version of the schematic. You'll have to scour through the board images.
U7016 is on the board view. Now you just have to get the eplist for your phone. I'll keep looking as well
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you very much for answering me♥. Do you think the problem is from the motherboard, which I understood from the schematic diagrams that the problem is in the U7016? Should I buy a new motherboard, but I'm afraid the problem is from somewhere else. Is that possible? I'm a little desperate to fix the phone, but I still have some hope.
из
Добавьте свой ответ
lina будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 80
