Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
Battery change in iPhone 4 and iPhone X both Moderately Difficult?
My question is really more rhetorical than asking for a real reason that both the iPhone 4 and iPhone X are shown as being the same degree of difficulty. I just got through changing a battery in an iPhone X. If that was moderate, replacing the battery in the iPhone 4 (Based on the video.) should be described as "Super easy". One has 6 steps. One has over 30, IIRC. Just sayin'...
Maybe it was because at the time, the levels hadn't traveled so far to the upside as they have now? The scales must have changed a lot. And I guess I get that. That said, you guys are definitely a valuable resource, and parts source, and a really big help. Cheers.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
I've answered my own "mostly rhetorical" question by replacing the battery in my old iPhone 4. There is no comparison in the difficulty levels between the two. The X was a royal pain, and had more things to go wrong while doing the replacement than the old 4. If one can't replace the battery in an iPhone 4, they probably have someone pouring their breakfast cereal for them as well. ;-) Cheers.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
MrRoundel будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 25
