PowerA's Gamecube Style Wireless Controller is a third party controller made for the Nintendo Switch. The controller is modelled after the beloved Gamecube controller, offering a wireless alternative to Nintendo's own controllers.
3вопросов Показать все
Does this use the same (abxy) buttons as the original GameCube
I wanna replace the buttons on one and I don’t know if I can use custom resin, 3d printed, or even injecting molded buttons for the original GameCube controller on it
Это хороший вопрос?
Оценка 0
1 Комментарий
Добавить комментарий
1 ответ
Наиболее полезный ответ
as long as you know what your doing, and use a guide, and have the right parts( and tools), it should work, and you need to make sure its meant for the wireless gamecube, and not a normal gamecube controller, as they could be very different inside. (although i don't think original buttons would work)
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Usually you can’t find replacement parts for 3rd party controllers online but I’ll look
из
you could if its a popular one, but you could maybe modify original ones(like sanding them down to the right size) if the controller is the same measurements as the original.
из
Добавьте свой ответ
Nednal404 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 83
