The Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems, such as sensors, receivers, and other electronic components.
Вопросов 13 Показать все
Hi I have a broken screen
Hi I have a broken screen to iv order about 5 different screen no luck I found a screen on ebay its a littel smaller 1.3 in but I'll take that instead of haveing to purchase another one can you tell me if this pin set will workhttps://www.ebay.com/itm/295458515399?mk...
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
In theory you could use it but it’s not the best option. I recommend you use the official part from there spare parts website.
Link for Flipper Zero Official screen:https://shop.flipperzero.one/collections...
Link for all Flipper Zero Official repair parts:https://shop.flipperzero.one/collections...
Basic soldering skills are required to remove an old display and install a new one.
❗️There are two types of displays. You will be asked to enter the details of your Flipper Zero during checkout, and the compatible display will be selected for you automatically.
❗️Check out the Flipper Zero Teardown Guide before trying to replace the part. It is important to carefully follow the steps and use proper tools if you don't want to hurt your dolphin.
REPAIR PARTS ORDERING RULES
  • Your order can have up to 2 repair parts
  • Your repair parts order can't contain any regular products (Flipper Zero and/or accessories)
  • Also Ifixit.com (where we are) has a complete guide on how to repair it/ connect the screen.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Tony Cash будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 122
