The Bose SoundLink Micro is an IP67 waterproof Bluetooth speaker. This device includes a strap and micro-B USB charging cable. Model number: 783342-0100
Where can I find a replacement silicone strap?
The silicone strap on my Bose Micro tore apart and won’t hold on to stuff anymore. The Bose hotline said they can’t help. I tried glue, doesn’t work. There’s got to be a way to replace the silicone latch?
Это хороший вопрос?
Счет 4
1 Комментарий:
I haven't had a problem with the strap tearing but the hook at the end no longer latches firmly and it pops out all the time. Trying to think of some good way to jury rig a new strap since the speaker is fine but it looks like there's no real answer but to buy a new one.
из
Добавить комментарий
1 ответ
Same issue here.
The silicone strap is a little torn and keeps on clipping off my bike bar.
I'd like to avoid replacing the whole speaker.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
There are silicone cages available if that doesn't solve it a cable tie will 👍
из
Any TPE rated silicone glue should work ive just reattached my completely torn off strap back to the speaker with a fairly strong hold
из
Добавьте свой ответ
Iwanttofixmystuff буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 512
