The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
Around 6 rows of dead pixels on only the left side
The left side of the game boy screen is completely blank but the right is in pristine. The left is missing out is missing a lot of pixels but it all works. Otherwise how do I fix this easy do I have to replace the screen?
Это хороший вопрос?
Счет 0
3 Комментариев
Also I can post a pic for reference
из
Can I please have a picture of the issue? I think I know what this might be.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is actually a very easy fix! Here is a video you can follow to remove the lines. The one horizontal line cannot be removed, but the vertical ones on the left are easy. You will need a soldering iron and make sure not to keep it under the screen for too long otherwise it will burn. More lines will appear as you work on it, but they will eventually all disappear. Good luck!
https://m.youtube.com/watch?v=-OEXhxoTIv...
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I don’t have an iron
из
I got mine at Hobby Lobby for super cheap. I also saw a Reddit post a while ago about someone fixing the Game Boy lines using a candle and butter knife.
из
Добавьте свой ответ
Sqwerks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 183
