Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
LCD Screen, which cable does what?
The LCD screen assembly has 3 connectors.
What I want to know is which cable is for what?
One of the cables will be the digitizer, one the LCD DATA and one the Backlight power.
Which is which?
Thanks
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Выбранное решение
Here is a site that has the tear down of the 3Gs: (The link is messed up so you have to type it in by hand. Sorry. ) See image above
http://www.rapidrepair.com/guides/iPhone...
Look at photo with step 2. If you click on the image it shows item #1 is LCD Screen, Item #2 is digitizer. I would guess the last one ( under #1 & # 2) would be your backlight power. (guessing)
The 3G looks to be the same as far as these spots indicate.
Hope this is what you needed.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you for that!!!
из
Take a look at the tear down. It should show you what you're looking for.
iPhone 3G Display Assembly Replacement
Оценка 0
1 Комментарий:
No actually it doe snot say which cable is which. Just that they are there and labeled 1 2 and 3.
I want to know which cable is for what.
из
if the answer has not been given by anybody, I may add tha cable 3 is for ear speaker and sensor that black out screen while listening to a call. Saeed Jabal
Оценка 0
#1 LCD Screen
#2 Digitizer
#3 Ear Speaker
#5 Headphone Jack
#6 Wireless
Оценка 0
Добавьте свой ответ
ViriiGuy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 11,194
