Will the fan of a A1176 fit on a A1283 Model?
Same as above
Это хороший вопрос?
Sorry for the delay!
Unfortunately, the fan from the A1176 models has a standard "4-wall" connector, and the fan from the A1283 models has a JST "3-wall" connector. They are not compatible.
Sorry!
Был ли этот ответ полезен?
No problem!
It is not urgent, thank you all!
Looking at www.mac-pro.com the two fans are enough different to not work properly. The one for the A1176 (1.6 GHz intel Core Duo) has a lower air displacement than the one for A1283 ( 2.0 GHz Intel Core 2 Duo). If you were to put the older one in the newer machine you would most likely run into air flow issues. The physical hight is less on the one for the A1176 so it may fit but not worth the overheating issue.
+ research
It would help if you had the part numbers. The expert on parts is Ben Eisenman. He should be to work in about 4 to 5 hours.
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 1,735
