Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
no sound from external speakers
I had to replace the original speakers, there was no sound and videos wouldn't play--error message appeared linking audio problem with inability to play video.
New speakers don't sound, video freezes up, but everything is fine if I use airpods, as the computer recognizes them as a new audio source
Everything else is ok with the computer
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like you have two issues here!
The first is a messed up headphone jack MacBook Pro 14" (A2442, A2779, A2918, A2992) and 16" (A2485, A2780, A2991) Headphone Jack
The jack also has a set of switches which push the signal between external and internal speakers.
I also think one of your internal speakers has a problem as well.
Replace a damaged or corroded 3.5 mm audio jack compatible with a model A2442, A2779, A2918, A2992 14" or model A2485, A2780, A2991 16" MacBook Pro Retina. Изображение
Товар
$29.99
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
tbk9800 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 157
