Why is my phone stuck on flight mode
My phone is saying no network connection, why?
Это хороший вопрос?
Это хороший вопрос?
That depends. We would need more information.
Is flight mode on?
Are you currently traveling?
Can you still use wifi?
Are you able to send texts or make calls?
Are you able to use mobile data, or not?
Был ли этот ответ полезен?
The flight mode is off and i can't make calls, text or use mobile data however, Wi-Fi is working fine. I am not travelling
Kindly assist
So, I would suspect one of two things.
First, your network settings may be bad. These are generic instructions, but should work with any android phone
Go to Settings
Go to reset options. This is typically within Settings itself, or within Settings>System
When you find reset options, click reset network options/reset wifi, mobile, and bluetooth
Once the reset is complete, hopefully it works.
If not, the other thing I would lean towards would be a SIM card problem. If you have a downloaded sim card, you should probably erase and redownload it. If you have a physical sim card, trying removing it and re-inserting it. You may need a new sim card
@duckmcquack thank you let me try this steps hopefully it work
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 78
