Why is my coffeemaker leaking water from the bttom
Water drains from the tank and leaks out the bottom of the machine
Это хороший вопрос?
Это хороший вопрос?
Does the issue happen immediately upon filling the unit or only when operating? If it only happens during operation I suspect a hose has either failed or become partially detached internally. Alternately, the tank has a small crack which only leaks as the unit heats up.
Был ли этот ответ полезен?
За последние 24часов: 4
За последние 7 дней: 13
За последние 30 дней: 26
За всё время: 287
@roberttuff what model is your coffee maker?
из oldturkey03
