What is the correct fuse?
What is the correct fuse to replace the old, that is burned.
Thanks
Это хороший вопрос?
Thanks
Это хороший вопрос?
If you changed the fuse three times and it burns out, you have a short circuit and/or overload in your system. The fuse is doing its job by protecting your circuits.
Был ли этот ответ полезен?
Look at the fuse side you will see how much the Amp on it and should the volt will be 110v-120v
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 773
2 Комментариев
What is the speed of your machine so I know which one you have?
из mayer
I change the fuse, in 3 times it burned, in other time nothing happening...
из Renan Andrade
