The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2вопросов Показать все
Вопрос закрыт
I can not turn on my nokia n95 8gb phone?
The screen shows the charging battery icon, the number keys lite up when pressed, battery has been charging for several hours, and does not show a full charge. The phone has been dorment for a long time, and im charging it through the usb adapter.
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Joe, if your phone was not used for a good while, I would suggest that you change your battery. It is possible that you battery is past the point of its life expectancy and not accepting a charge. Good Luck
Был ли этот ответ полезен?
Оценка 2
joe ur granda ma must have eat the batterey
Оценка 1
my nokia n95 is power on after month but it is no power how iam on my mobile self
Оценка 0
you should use 12 voltage of any charger to shock the battery of n95 for 8 second because i think it was just drain... if u have more problim you can call me baby,,, 09098016760
Оценка 0
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 4,264
