The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
Это хороший вопрос?
Это хороший вопрос?
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
Был ли этот ответ полезен?
but it can detect my other SSD
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 43
За все время: 2,037
1 Комментарий
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
из Mahedi Hasan Suman Поделиться
