The 2000-2006 BMW X5 models were the first generation (E53) of BMW's sport crossover years. The X5 was first released in 1999 for the 2000 model year and featured all-wheel-drive with either an automatic or manual transmission.
2003 X5 no audio after battery replacement?
Hello bimmer friends. After new battery install in my 2003 X5 the audio is completely absent. No Prior issues with sound system and everything is factory. The radio still turns on and displays show normally, it can scan through stations and adjust settings/volume like always, but no sound. There is no crackling or buzzing or anything like that, just total silence in any mode, CD, radio, Bluetooth adapter.. silence. It doesn't ask for a radio unlock code or give me an option to enter one. Any ideas? Could it be an Amp issue? I've checked all the fuses, and there are no relevant codes showing in diagnostic... I can't afford a professional repair for a non-essential issue like this -keeping it on the road in one piece is bankrupting me as it is. Any advice would be greatly appreciated! Its been like this for months and im going crazy from long, silent drives when I forget my headphones....
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
The most likely reason would be the new battery has fried the speakers themselves this is what happened to my Audi S7 when a new one is replaced sometimes the resistor is so old it can not take the amps given and fry the components Kicker audio has some the best and cheapest speakers on the market rn go to the Ds series car speakers find your car size and order then there is no need to upgrade anything else with this speaker's everything can be completely stock with this speakers and about 20-30 minutes to fix the issue. I hope this helps. :)
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you so much I will try this. I never would have thought of that. So all I need is the new speakers not the Amp or resistors?
из
Добавьте свой ответ
Jessica Kidd будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 8
За последние 30 дней: 26
За всё время: 629
