ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Dropped MacBook: Black screen but works on external display
I've dropped my macbook on the floor πŸ€¦β€β™‚οΈ and its edge of the screen got damaged (see attached img). After dropping despite the damage in the corner it was still completely functional but after another 24hrs the macbook screen went black (not completely black because when it boots up i can see very dimmed bright apple logo).
The macbook works on external display.
I've tried to restart NVRAM/PRAM but without any effect.
Do i have any affordable options instead of screen replacement assuming i can live with the damage in the corner of the screen?
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
ΠžΡ†Π΅Π½ΠΊΠ° 0
1 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
I've ordered required screwdrivers and will try to plug in and out the lcd cable, hope it works 🀞
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠžΡ‚Π²Π΅Ρ‚ΠΎΠ² (1)
НаиболСС ΠΏΠΎΠ»Π΅Π·Π½Ρ‹ΠΉ ΠΎΡ‚Π²Π΅Ρ‚
Sounds like the display has failed due to the damage. It would require some pretty advanced skills to repair the display itself. At this point, the cheapest option would be to continue to use an external display. Otherwise, you'll want to look into display replacement options through Apple or a third party. Good luck!
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
ΠžΡ†Π΅Π½ΠΊΠ° 1
6 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²:
Thanks for your answer πŸ™ Do you think it's worth trying to plug out & in the lcd cable or that surely won't solve the problem?
ΠΈΠ·
It's worth a shot! But my best guess is that it won't fix the issue. Good luck!
ΠΈΠ·
thanks! i'll give it a try 🀞
ΠΈΠ·
One more question please. Can i open the lower back and try plug in and out straight away? Or maybe i need to go every step as detailed in MacBook Pro 14" 2021 Screen Replacement screen replacement guide? I'd rather avoid unplugging battery board, trackpad etc
ΠΈΠ·
@ares12355 You should disconnect the trackpad cable and the battery first in order to prevent damage to the display. I'm pretty sure that if you disconnect the display while the battery is connected it could potentially damage the display board.
ΠΈΠ·
ΠŸΠΎΠΊΠ°Π·Π°Ρ‚ΡŒ 1 большС ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
ares Π±ΡƒΠ΄Π΅Ρ‚ ΠΎΡ‡Π΅Π½ΡŒ ΠΏΡ€ΠΈΠ·Π½Π°Ρ‚Π΅Π»Π΅Π½(Π°).
Бтатистика просмотров:
Π—Π° послСдниС 24 час(ΠΎΠ²): 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 0
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 7
Π—Π° всё врСмя: 293
