2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
Laptop only boots when you do a hard SMC reset
From what the eBay seller of the system tells me:
Laptop only boots when you do this:
  • Unplug power
  • Hold power button down
  • Connect reconnect power
After a few seconds it will chime, then let go of power button
Note it will run with fans at 100% the whole time. Also battery is dead, so if you unplug power, it will shut down. I found this tip on here on iFixIt.
Not sure what is wrong with the laptop, had previously thought it was dead and unable to boot, but it can when you do the above. I have tried SMC and PRAM resets to no avail.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
This sounds like it could just be a dead battery. See what happens if you disconnected the battery and try to power up.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I will let you know when I receive the device I ordered it on Ebay I just posted it so I can get some answers
из
Добавьте свой ответ
Maimlian буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 145
