Why does my phone charge for long
Phone charging system
Это хороший вопрос?
@habib2927 @akshayshri55686 this can have many different reasons. First start by making sure that your charger supplies the proper voltage. Next check the charging cable. Make sure that there are no bend. broken. or corroded pins. Now focus on the charging port. A few drops of high-grade isopropyl alcohol and a few puffs of compressed air will clean out the port.
If all of this does not work, then it might be time to disassemble your phone. Think about replacing the battery as well as the USB charging port. Anything after that, will require some board level repair. For that you need to have the tools, the schematics and the experience to repair that.
Был ли этот ответ полезен?
Well I will suggest you to replace the battery of your mobile phone and keep cleaning the junk files from your phone and remove the unwanted apps which run in the background.
Had the same issue before—turned out my charging port was full of dust and lint. I used a toothpick to carefully clean it out (gently, so I didn’t damage the pins), and suddenly my phone was charging normally again. If you’ve had your phone in your pocket a lot, dirt can build up and block the connection.
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 56
За всё время: 1,847
2 Комментариев
Charging is very late
из Akshay Shrivastav
Why my phone décharge kwikly?
=== Update (02/02/25) ===
Pourquoi mon téléphone s décharge vite?
из Symbo Tv
