Can I "glue" my touchscreen as it is cracked
It runs just fine with it's keyboard and having the touch feature turned off, But, it would be nice to have touch back.
Это хороший вопрос?
Это хороший вопрос?
Hi @drossowen,
I've been checking around but can't find any indication that the front glass/digitizer on your laptop can be replaced separately from the LCD. Every site I can find only sells them as an assembly, which usually means they would need specialized equipment and expertise to separate them. That tells me they're fused together and can't be replaced by us normal DIYers. Usually that sort of replacement requires a vacuum table with wire guides, a vacuum chamber and a UV chamber, none of which most of us have lying around.
So if you want to fix that touch screen, it looks like you'll have to replace the complete display assembly. Here's the iFixit guide showing you how to do that replacement.
Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement - iFixit Repair Guide
If you want, the Microsoft Service Guide is also available with the "official" instructions.
Surface Laptop 3 And 4 English Service Guide - iFixit
It's rather expensive, but you can buy a replacement screen right here on iFixit if you want to support their repair efforts.
You can, however find them substantially cheaper at the big retail parts outlets like Amazon, eBay and AliExpress. Here's one that came up on my cursory search; I'm sure you can find lots more to choose from.
Был ли этот ответ полезен?
@drossowen no. That wont work. There is a very fine matrix that runs through those touch screens, that is fractured. The only way to fix it is by replacing the display assembly. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 24
