My MacBook is not taking any macos
Hi All,
I have a MacBook pro 2010 that had a bad motherboard and I went ahead and bought one from eBay and installed it.
But after installing it it won’t take any Mac OS I tried swapping SSDs I tried replacing SSD cable I tried different macOS it’s getting super slow when loading the OS from the USB drive.
One thing that I notice though is the original logic board that I had a 2.4 GHz CPU, the new one that I bought has a 2.66 GHz CPU. Is it possible that the new motherboard is not compatible with the components in my MacBook?
It shouldn’t matter because than you logic board fits perfectly. I didn’t have to force it or anything. I tried resetting NVRAM/PRAM reset.
I’m out of luck at this time. Please advise.
Это хороший вопрос?
2 Комментариев
Please tell us what system you are trying to install, any failure message you are getting and the date of the installer.
из mayer
Im trying to install A1278 model2351 it has 2.66ghz cpu
The one i initially had is A1278 model 2351 but has 2.4ghz cpu
No error msg, just whenever i load the os from the usb to install, the bar gets stuck and doesn’t move
из Redwave
