How to replace memory
i need to remove the hard drive
Это хороший вопрос?
While the SSD drive is removable as you can see here in Step 11 in this teardown which is exactly the same as your system MacBook Pro 13" Function Keys Late 2016 Teardown it uses a custom interface, so unless you have a second function key system to plug it into you can’t access the data within it.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 84
