Waterproof digital camera released in 2014. The Olympus Tough TG-3 is a Wi-Fi capable, compact camera.
Why does my camera automatically power off after a few seconds?
Have a TG-5 (very similar to TG-3) that has worked fine, but now automatically powers off after a few seconds, with fully-charged battery or being plugged into adapter. BTW, it's never been submerged in water. Perplexing! Any suggestions (besides sending it to $$$ Olympus repair). FYI, I've disassembled it to check on ribbon cables - all attached.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Not an expert on camera electronics but may suggest a few simple things to check, based on your diy skills. If disassembly doesn't scare you then you may be able to verify power is adequate (battery or adapter) and reaching input connections. Verifying actual power is reaching main power connections is important to separate a power issue from camera electronics. I tend to presume power first before considering electronics failure. Of course, random electronics failure do occur whether inflicted from external influences or internal. Using a multimeter is crucial here for diy diagnosing.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
rgstout буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 482
