Repair and disassembly guides for Kenmore Microwaves.
182вопросов Показать все
Can I replace the power cord in a microwave?
I sometimes need to change the cord position to get my old Kenmore microwave to stay on or work at all. So it seems the cord should be replaced. Has anyone done this, would a cord be hard to get, and are there any issues with danger of getting shocked or anything even though the unit is unplugged?
Это хороший вопрос?
Оценка 1
1 Комментарий
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list. Thanks so much.
из
Добавить комментарий
5 Ответов
Выбранное решение
I replace a power cord on a radio, the conductor ends were looped around terminal screws so I just had to undo the screws and replace the cord. I just made sure the larger blade of the plug matched the old connection. I purchase my cord with plug at home depot.
The hardest thing is how to take it apart, you may want to do as this web site does and take pictures with a digital camera or just make a drawing and tape the screws to it.
The cord will most likely be held by a clamp or by a fitted strain-relief device
Have you test the outlet, just to make sure its not it?
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Well, it turned out to be a bad outlet in the power strip I have it plugged into, as mr5989 suggested. I had a different microwave plugged in for awhile, as sort of a test, and it seemed OK for awhile but then started doing the same thing. Maybe the outlet was getting worse and worse. Eventually I plugged the original microwave back in but used a different outlet on the same power strip, and it has been fine for a few months now. Sorry to get you guys going on this when it was something so simple, but you've given some good information in case anyone here ever does have to replace such a cord. I really thought by the way I had to move the cord around that it was the cord itself, and next time won't jump to that conclusion.
из
Remove your access panel, and take out the old cord. You can use a computer power cord. Just cut off the end and strip back the outer casing. You will find a Black, White and Green wire. Just connect the wires to the same terminals in the Microwave, Replace your covers and you are set to go. (N.B. Some makers solder the ends of the wires or use crimp connectors )
Just make sure that the gauge of the new cord is the same as the older one one the microwave.
Оценка 2
4 Комментариев:
Thanks. It sounds like it might not be too hard as long as there's no danger of being shocked from anything internal to the microwave, as might happen with some electronics, I've heard. Anyone think so?
из
Watch out for capacitors.
из
I don't know about the computer cord. It might not handle the amps. Be sure the diameter of the copper wire (the gauge) is as large or larger than the original.
из
Beware of capacitors. Never touch one. They are cylindrical shaped and around the same size as a medicine bottle.
из
It Could be a Screw Loose on the Connector(s)at the Other end of the Power Cord.Either Way,You will see once you remove the cord clamp/holder.If the Screws are Not Loose,Then i Would Replace the Cord,cause there could be a broken wire.Just make sure it is the same Gauge wire,i would'nt recommend to go thicker in gauge wire,unless you want problems.Keep it the same and you will be ok.
Оценка 1
Thanks, and do you mean don't touch the capacitor? Could you tell me what it looks like and how to avoid it? I can look for a picture online somewhere. I guess this isn't a high priority, since I haven't attempted the repair yet, and have another microwave to use. But at least you are the first person to address that part of my question, so thanks again. Anne
Оценка 0
1 Комментарий:
They are cylindrical shaped and about the size of a medicine bottle. Never touch one, they can kill.
из
Can you add a longer cord or will it reduce the power.
Оценка 0
1 Комментарий:
My husband just exchanged our 2 foot original microwave cord for a 6 foot cord because it wouldn’t reach the outlet. He purchased it from Home Depot. He made sure that the gauge was exactly the same as the old cord.
из
Добавьте свой ответ
akwellings будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 41
За всё время: 16,459
