The Protocol Galileo Stealth is a quad-copter drone released in 2016. It features multi-directional controls, a 2 megapixel 1280x720 camera, and HD Wi-Fi livestreaming.
Вопросов 6 Показать все
Drone tilt's upon takeoff
Drone tilt's to one side upon takeoff
Это хороший вопрос?
Оценка 0
2 Комментариев
@angelocenotti got a make and model for this Drone?
из
it is a protocol galileo stealth w/camera
из
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
@angelocenotti,
Have you checked that all the propellers are situated in their correct position and are orientated correctly i.e. not upside down?
usually propellers are marked as to where they should be place on the drone and also what side is facing up.
Most user manuals for drones show how to connect the propellers to the body of the drone
Был ли этот ответ полезен?
Оценка 1
Check nothing is interfering with the motors on the side that lifts last. One motor isn't spinning up as fast as the others causing the drop in one side. It's possible you may need to fit a new motor. Try a drop of fine oil on the shaft at the bearings incase they are a bit dry.
Оценка 1
Добавьте свой ответ
Angelo Cenotti будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 91
