Drone tilt's upon takeoff
Drone tilt's to one side upon takeoff
Это хороший вопрос?
Have you checked that all the propellers are situated in their correct position and are orientated correctly i.e. not upside down?
usually propellers are marked as to where they should be place on the drone and also what side is facing up.
Most user manuals for drones show how to connect the propellers to the body of the drone
Был ли этот ответ полезен?
Check nothing is interfering with the motors on the side that lifts last. One motor isn't spinning up as fast as the others causing the drop in one side. It's possible you may need to fit a new motor. Try a drop of fine oil on the shaft at the bearings incase they are a bit dry.
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 91
2 Комментариев
@angelocenotti got a make and model for this Drone?
из oldturkey03
it is a protocol galileo stealth w/camera
из Angelo Cenotti
