Адаптер питания переменного тока для MacBook, MacBook Pro и MacBook Air. Использует самоцентрирующийся магнитный разъем, который безопасно отсоединяется при рывке. Зарядные устройства MagSafe первого поколения (2006–2012 гг.) имеют разъем L-образной формы чуть большей толщины. Доступны версии мощностью 45 Вт, 60 Вт и 85 Вт.
Replacing Magsafe "T" connector with an "L" connector
Hi,
I have a Magsafe 85W with a broken T connector, and I have a Magsafe 85W with an L connector but a failing power supply.
So I want to replace the broken T connector with my other L connector.
It would be ok to join both cables in the same order, the inner cable of the T power supply, with the inner cable from the L connector, and the outside cable with the outside cable from the L connector?
Thank you!
Esteban
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
Sure. I interchange them all the time.
Был ли этот ответ полезен?
Счет 5
1 Комментарий:
Thank you for answering, it's working perfect.
из
Like the previous answer. Connect the inner cables together and the outer cables together. I just did it and it works perfectly.
Счет 0
There's supposed to be a "fix" that simply is a small adapter thats plugs both tips together so you don't have to buy (or fix switching cables) a completely whole new charger when all you need is the T tip to be an L tip. Anyone know how to even find it? I did once before but I didn't save it, and Applestore doesnt know what im talking about. Supposedly Apple knew of this "tip" change from the T tip to the L tip on their chargers, and made a simple small adapter to plug both tips into for connection. IN other words, if you had the T tip charger, but you need the L tip charger, you dont have to buy the WHOLE CHARGER, just use this small tip connector adapter.
Счет 0
Добавьте свой ответ
Esteban Eid буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 23
За все время: 9,414
