Random Disconnects On PC After 1 year
The computer keeps randomly disconnecting im not sure why
Tested the Ethernet cable and that's good. Happens on hotspot, Wifi & ethernet.
Updated everything including motherboard and still happens. Only device on network this happens too
My PC Build
- CPU: AMD Ryzen 7 5800X 8-core
- CPU cooler: NZXT Kraken X53?
- Motherboard: MSI X570 Gaming Edge Wi-Fi
- Ram: Trident G-skill F4-3000C16D-16GTZR x2
- SSD/HDD: Samsung 980 Pro 1TB
- GPU: AMD Radeon RX 6900 XT
- PSU: EVGA 1300XT
- Chassis: NZXT H7?
- OS: Windows 11
- Monitor: ASUS TUF VG27A
Это хороший вопрос?
9 Комментариев
Hi @alexduncan10584,
How do you get it to reconnect after it has disconnected?
Does it only disconnect when you're connected to the same website or any?
Check in Event Viewer for any Critical, Error or Warning events that may be logged at the time the PC disconnects online.
Check in Device Manager > right click LAN network adapter (and WLAN adapter as well) > Properties >power management and check that the option to turn off the device is not enabled
из jayeff
Tithe disconnect is extremely brief it happens to the point windows doesn’t know it’s happening. Hardly shows in a ping test
из alex duncan
@alexduncan10584
If it's that brief, how is it affecting online use?
Does it also occur on other devices that are connected to the same Ethernet port (or if WiFi), in the exact same location as the PC? There may be some kind of interference occurring (EMI?) which affects the data signal and the adapter has to re-train the connection between the PC and the modem
из jayeff
Call of duty and other game services notice it
из alex duncan
@alexduncan10584
Was editing comment when you answered, see update
из jayeff
Показать 4 больше комментариев
