Информация по ремонту посудомоечных машин Bosch.
E15 error but not on eco mode
Hi,
My Bosch dishwasher works perfectly as long as I only use Eco mode. Any other setting fills the base up with water after 40 minutes or so and triggers e15. I can use the machine on eco and it’s alway bone dry every time. What’s different to make it leak if not on eco mode?
Many thanks
Это хороший вопрос?
Счет 0
2 Комментариев
@steve39461 what exact model is your DW?
из
It’s a series 6 Aqua Star
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
The E15 error code on a Bosch dishwasher means that the dishwasher has detected too much water and there's a risk of a leak. The control board receives a signal from the flood switch, activates the water pump to drain the water, and then turns the dishwasher off. The error code could also be caused by a control board glitch.
To fix the error code, you can try:
  • Turning off the water inflow
  • Performing a hard reset by disconnecting the power to the dishwasher for five minutes
  • Tipping the machine to drain the water and investigate the source of the leak
I have found a couple of things are the culprit:
  1. Inlet valve faulty and leaking (Replace)
    1. You'll be able to feel it leaking if this is the case
  2. Fill Hose leaking into the base
  3. Sump Gasket or Diverter Valve (Replace)
    1. This can be tricky. You may be able to put food coloring into the sump and let it run to see where staining shows up.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
That gives me a few ideas where to look thank you. The machine never leaks in Eco mode and works fine for months on end. Put it in auto or intensive and it doesn’t make it through a single wash before E15 come up.
из
Did you ever figure this out? We have the exact same issue with our Bosch dishwasher. Eco mode works fine, Auto mode triggers the pump running non-stop and E15 error code.
из
We are having the exact same problem. Service tech says it is a bad diverter valve which happens to be on backorder with no ETA. Anyone get theirs working again?
из
Fixed this issue 3 times. To fix and prevent this E15 issue from happening to your Bosch dishwasher, just check out this vid. It’s all there! Fix and Prevent E15 Bosch Dishwasher Error
Счет 0
1 Комментарий:
Hello Steve, my dishwasher pump is making the suction noise even with no water flowing and even with the door open, the pump starts working... After some research it seems it could be a leak and that there is water around the base... I am trying to find a video that shows me how to fix it... the video you shared here cant be seen, it states "Video unavailable,
This video is private". Can you please make it public? The machine isnt showing any errors, just making the noise... and it doesnt start any cycle. Many thanks
из
I’ve fixed this issue multiple times. Here is a really handy video on how to fix and prevent the Bosch E15 dishwasher error code. Fix and Prevent Bosch E15 Error Code
Счет 0
2 Комментариев:
Thank you for that, unfortunately I’ve done all of that. I don’t get this problem as long as I use the ECO setting every time, it never plays up. If I use intensive mode then E15 is back within 20 minutes and I have to get the water back out of the base. Same with Auto mode unfortunately.
из
Gosh that is so strange. I cannot think of a reason why that would happen like that!
из
Добавьте свой ответ
Steve буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 32
За последние 30 дней: 143
За всё время: 6,307
