How to reattach the globe?
What is the trick to reattach the globe? I align the 4 screw into the slots on the base but nothing locks the globe to the base. Any suggestions?
Это хороший вопрос?
Это хороший вопрос?
Have you tried turning the globe? There's usually only two possible methods of locking. Either align and then turn or align and then tighten!
Был ли этот ответ полезен?
Yep. there are 4 screws that fit into slots on the yellow base. Once the screw heads are in the slots, it doesn't turn and doesn't lock
My next question would be are you sure you've used the correct screws, next is it possible to set the globe on them install the screws. If you could post some pictures of the slots in the globe and of the four screws your talking about?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 24
