Vertical lines minutes after replacing screen
My 2017 Macbook Pro decided to have an issue with the screen, similar to the one found in Vertical lines after dropping, though it was only when the lid was open at certain angles. A quick look online and a brief read said the problem was likely the screen, so I decided to replace the screen, getting from MacBook Pro 13" Retina (Late 2016-2017) Display Assembly the Used Premium screen, and after an amazingly quick delivery turn around of maybe a week, I was off to the races following the guide to replace the screen.
After following the instructions carefully, I was successful in replacing the screen, and it seemed to work perfectly, though less then 10 minutes of use and the screen started to show the issue in the image and I am absolutely confused. I reopened the macbook, rechecked everything against the pictures, and everything as far as I could see was identical to the images, nothing seemed off.
Any suggestions would be greatly appreciated, as I'd like to avoid having to pay a 3rd party to repair my repair, and also to learn what I missed
Это хороший вопрос?
