My screen is broken
Hi,
My screen is broken and it's black. Is it okay to skip the step where it says disable your Mac's Auto Boot?
Also, Where do I buy the screen?
Это хороший вопрос?
Hi,
Это хороший вопрос?
You should disable Auto Boot, I would use an external display. A cheap HDMI display with a HDMI to Thunderbolt adapter will do.
As far as the display iFix it sells them MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide MacBook Pro 13" Touch Bar 2019 Screen Replacement
Do be careful, a virgin display won’t have the SameTime camera activated, you really want a used one.
Был ли этот ответ полезен?
Thanks Dan,
Do you mind guide me on how to use an external display, I'm planing to use an iPad (5th generation, Model MP2JAE/A) as external display, I used the same Wifi and tried to open the macbook pro the screen was black it was connected to the Wifi but I couldn't do the mirroring between the iPad (5th generation, Model MP2JAE/A) and the macbook pro.
Do you mean to use Lightning and USB-C Cable? Between the ipad and the macbook pro?
@asmaa51256 - Sorry, screen sharing via an iPad is not what will work in this case.
You need a regular HDMI or DP display some TV's offer this connection so check what you have. Then depending on its connection get the needed cable and adapter.
unfortunately, I only have this ipad and the macbook pro with broken screen no other devices that can be used as external display.
So, can I use this ipad (5th generation) as external display in this case?
Thanks for your help.
@asmaa51256 - Review this Use an iPad as a second display for a Mac
As you can see, the issue you face is you can’t enable it without a working display (Catch22 problem).
Do you have a friend who has a workable HDMI display that will let you use it?
If that’s not possible I fear you’ll need to seek out an independent Mac repair shop or take the chance of messing up the system.
Know your limits and the risks. A small display on the used market can be gotten for less than $100, think it this way… would having a second display be so bad when you need to read a dialog and need to write what is being offered in the dialog or reading something on a Zoom call which I just did.
Got it, Thanks for your help Dan.
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 87
