Newly replaced Freezer fan not running
Just replacedGE Cafe freezer fan and did not turn on automatically. Does it need time to run for a while (fridge was turned off and defrosted) before it kicks on?
Это хороший вопрос?
Это хороший вопрос?
Why did you replace the fan in the first place? What symptoms were you experiencing?
Move the refrigerator away from the wall to access the back. Then, remove the lower rear access panel and place your hand on top of the compressor to check if it's warm and running. Additionally, ensure that the condenser fan, located next to the compressor, is also running.
The fan you replaced, known as the evaporator fan, is an integral part of the entire refrigeration system. Its function is to draw air through the evaporator coils, extracting heat from the circulating air. Normally, the evaporator fan should start running as soon as the refrigerator's compressor turns on.
If you can provide your model number (ideally a photo of the sticker to rule out any typos) I can try to find more repair information for you. Some other things to look into:
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 27
