The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
Using the adhesive tape to reattach the screen - Need help
I am struggling using this this iPad Pro 11" (2018/2020) Adhesive Strips to reattach the screen to the ipad. Has any one done this successfully? I have gone through two sets of tape.
There are no clear step by step instructions on how to apply and use the tape.
Replace the custom cut adhesive strips that secure the front panel to the case compatible with the 11 inch iPad Pro tablet 2018 and 2020 models A1934, A1979, A1980, A2013, A2068, A2228, A2232, and A2233. Изображение
Продукт
Это хороший вопрос?
Оценка 1
1 Комментарий
What seems to be tripping you up?
из
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
iPad Display Assembly 3 Pc. Adhesive Application
Был ли этот ответ полезен?
Оценка 2
Totally remove the screen. Remove any traces of the old adhesive from the frame using either alcohol and a cotton bud or a small scraper type blade. Try and remove any adhesive lumps or strips from the screen by rubbing with your thumb. Apply the tape to the sides, top and bottom of the screen then peel off the protective film from the strips, then reattach the cables and fit the plate and screws. Turn on the ipad and check the screen works correctly then close the screen up. Gently press around the the screen to ensure adhesion of the tape. Personally I use tessa tape. Sometimes running a hair dryer around the edges of the screen to heat up the adhesive helps it stick better.
Good luck.
Оценка 2
Добавьте свой ответ
Hermann будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 161
