Hi Sheena,
Just to add to my esteemed colleague's excellent information, after the iPhone X, Apple started pairing screens with the logic board. My understanding is that the only detrimental effect of that is to give you that "may not be genuine" warning. In addition, replacing the screen causes you to lose the True Tone function unless a bit of data is copied from the old screen to the replacement.
I get the impression that you didn't do the replacement yourself, but rather had a shop do it for you. Assuming Face ID, True Tone and Automatic Brightness functions are all working, then they did a reasonable job other than the fact that they used an inferior quality screen. Aftermarket shops can get around all of the other issues except the genuine warning unless, as Justin said, they remove a chip from your old screen and transplant it to the replacement.
Outside of that, which requires somewhat specialized equipment and expertise, the only other way to get rid of that warning is to buy the screen from Apple and either have them replace it for you, or make use of the self repair program. You'll pay quite a bit as the screens they sell are expensive plus they charge a fair amount for the repair. With the self repair program you still have to rent their equipment in order to do the job yourself, but then you get access to the configuration tool that lets you pair the new screen to the phone.
Forgot to mention, but yes I agree that your replacement screen is most likely an LCD rather than the newer OLED technology. If that's the case, the replacement will, as you observed, have much lower image quality and resolution, plus it will be slightly thicker than the original because of the need to add a backlight layer. That also means it will use more power than the OLED, resulting in shortened battery life throughout the day. And since the LCD is printed on glass rather than the flexible plastic like the original OLED screen, it can't be curved to match the front glass so it can't extend all the way to the edge of the screen like an OLED.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
