This is incorrect. SD18C72311 is the secondary (external) screen. OP needs the main (internal, foldable) screen.
If you want to use that website, this is the correct link:
https://mpdmobileparts.com/products/moto...
The part number is listed as SD18C73223.
However, if you search that part number, you only get a few results. You get MPDMobileParts saying it is for the XT7041, and a few other websites claiming that part number is for the XT7000 (i.e. the 2019 model of the phone as opposed to the 2020 version of the phone). Those two models are not intercompatible, according to a few other sources.
I am not familiar with the website you linked, so I will not say one way or another which is right and which is wrong about the part number, but given those results I am not 100% confident that is the correct part and would be compatible with OP's phone.
Still, a source that gives part numbers is a good resource to have and I will be bookmarking that website for later cross-referencing. Thank you for teaching me about the existence of that resource.
UPDATE - July 19th, 2023
This was originally a reply to Matt's comment, hence the phrasing that does not make sense as an answer. I do not know why it got changed to "answer" but... *shrug*. Hopefully this explains the context.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
3 Комментариев
INFO:
Do you need the main (foldable) screen, or the secondary (outer) screen?
Can you confirm your exact model number? Is it XT2071-4?
из Justin Castle
@erelectronics hello,
I am looking for the foldable screen, and XT2071-4 is the correct model number. Thanks
из SteveJobs
I also need a source to buy a replacement external screen for moto razor plus 2023 I also seen a fella on utube HUGE JEFFERY SAID HE SOURCED ONE FROM I FIX IT .
из John Zurlo
