Can I take a hard drive from an iMac and boot from it on my MacBook Pr
Can I take a hard drive from an iMac and boot from it on my MacBook Pro to use the iMac as a portable computer?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Can you explain your reason here a bit more.
Are you wanting to access the iMacs data from your MacBook Pro? Either locally or remotely.
Are you trying to setup your MacBookPro as a replacement of your iMac?
You don’t need to remove the drive from your iMac to attain that!
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Screen is destroyed and it’s a work computer and need to work in the interim
из
@bg234 - Which system has the damaged display? iMac or MacBook Pro and which model as that also effects the answer.
из
Добавьте свой ответ
bg234 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 123
