I have a problem with the TouchPad
Hi, I’m Vivek Chaudhary from Rewari
I have a 15” MacBook Air with problems with TouchPad
Это хороший вопрос?
Это хороший вопрос?
This system should still be covered under Apple warranty as it was just released. Are you sure you picked the correct system? To be sure plug in your systems S/N here EveryMac - Lookup see what it tells you, the newer models won’t report correctly, even still let us know.
As to your problem, did you have a liquid spill (or get it wet) or damage the system in someway?
Был ли этот ответ полезен?
you should get the trackpad replaced i believe,thats what it is most likely like 99% chance that its that
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 96
