Audi unveiled their brand new generation A6 model at the 2011 North American International Auto Show, in Detroit. Featuring a more conservative design and borrowing design cues from the A7, the new A6 comes with LED taillights, an integrated trunk-lid spoiler, a dual exhaust system, and optional LED headlights.
How do I repair my mass airflow?
Car keeps shutting off when at redlights and stop signs
Это хороший вопрос?
Счет 2
1 Комментарий
Hi @freddydilogene,
How do you know that there's a problem with the MAF or MAF sensor?
Have you checked the OBDII codes?
If so was it a P0101 or something else?
If you haven't checked the codes, I suggest that you get them checked to see what codes are there as it may be something else that is the cause and not the MAF sensor.
These are the more common problems with a faulty MAF sensor:
The engine is very hard to start or turn over.
The engine stalls shortly after starting.
The engine hesitates or drags while under load or idle.
Hesitation and jerking during acceleration.
The engine hiccups.
Excessively rich or lean idling.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi Freddy,
As @jayeff has already stated, we need more information to be able to give you a diagnosis we're confident of.
If you suspect the Mass Air Flow sensor, there's an easy way to test it. Simply unplug it and drive the car. If the stalling goes away with the MAF unplugged, then yeah, it's pretty certain you need a new one. If the engine computer can't get a reading from the MAF, it defaults to preprogrammed settings that will allow the car to be driven but won't give you the optimal fuel economy and power settings achievable with a MAF. With a bad MAF those default settings will run better than the incorrect readings returned by the defective sensor.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Monique de tirage
из
@abdallahchiheb I would love to respond, but your message isn't long enough for Google Translate to be able to help me understand what you're saying. Please translate for me or indicate what your native language is.
из
Добавьте свой ответ
Freddy Dilogene буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 21
За последние 7 дней: 109
За последние 30 дней: 437
За всё время: 5,439
