Swap tcon Hisense 55p7 65r7
Hi, can I use a tcon from 65”tv in 55”? The model is different obviously but am curious as to what could go wrong. My tv was flickering and so far I changed a power board and main board from a newer model (which works fine by the way) but it still flickers after an hour of watching. So the only part left is Tcon :)
Thanks for answers
Это хороший вопрос?
2 Комментариев
My has a combined tcorn on board how can i change or wat ic should i change help
из Handsome Ndlovu
Greetings,
I have a Hisense 55-inch TV (model 55R7). The TV works perfectly at first and shows a great picture, but after about one to one and a half hours of being on, the picture starts flickering and rolling from the bottom to the top of the screen. I suspect the T-con board (50T32-C0D CTRL BD) may be faulty.
I am looking for a T-con board for a Hisense 55-inch TV (model 55R7). Specifically, I’m interested in Hisense T‑CON Board 50T32‑C0D CTRL BD (or equivalent part for my model).
Could you please check if you have this board in stock, and if yes:
• confirm the exact board part-number and compatibility with model 55R7
• send a clear photo of the board you have (so I can compare connectors and layout)
• let me know the price, shipping cost to Melbourne, Australia, and approximate delivery time
• what your return policy is (in case it doesn’t fix the issue)
Thank you for your help.
Best regards,
Barry Missaghi
Electronics Technician
из Behrouz Missaghi
