Why is my screen showing distorted images/ colors?
Посмотреть содержание изображения:
Это хороший вопрос?
Это хороший вопрос?
There are a few reasons why your screen might be showing distorted images or colors. Here are some of the most common reasons:
Here are some things you can try to fix this:
If you have tried all of these things and you are still having problems, you may need to contact a computer repair technician for help.
Был ли этот ответ полезен?
This is a SNES not a computer. So not sure that if what you put applies to some degree or not here.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За всё время: 147
I have tried different power supplies, RF cable and R/W/Y composite cables. No difference. Also cleaned cartridges and pins in the console.
из Talonrevenge
@talonrevenge Have the electrolytic capacitors on this console been replaced?
из Andrew S
@andrewsawesome not that I am aware of.
из Talonrevenge
@talonrevenge Have you cleaned the pins on the video connections or the cartridge connections?
из Justin Castle
@erelectronics yes I have cleaned them.
из Talonrevenge
Показать 2 больше комментариев
