Not charging was working while it was charged
Not charging it works it was while it was charged
Now it's dead and the charger is also fine pls help.
It is Lenovo tab M10
Это хороший вопрос?
Это хороший вопрос?
@champtichaubey couple of things you could try. If you are sure that your charger is working, get a USB-C ammeter and connect it between the tablet and the charger. Let us know how many amps your tablet "pulls". If is does not, then the issue could be the battery or the charging port. For that, you will have to take it apart. Now, if your tablet is a M10 (TB-X605F) use this guide to work on it. If it is a TB-X505F then you are in luck. That model has a separate charging board. To work on that, use this guide
If it is neither, let us know what exact model yours is.
While you work on your tablet, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
My tablet is not charging I think the wire is broken from inside the tablet
It is M10 tablet it work when was charged but now it is not charging
Yes it is M10 tablet
Did you try the suggestions as shown in the Most helpful Answer above?
The back comes apart with a guitar pick need precision screw driver set for tools remove battery copy model number from old battery and buy genuine new and replace good to go!!
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 24
За все время: 1,163
