Why is my phone charging slow?
When I plug the charging cable into the A32, it says slow charging and it doesn't charge at all, I tried with all chargers from my house and the original one.
Это хороший вопрос?
Это хороший вопрос?
Loose contact of charging connector or old lightning cable makes such a case in my experience. Check this first if same then you may replace the charging connector.
Был ли этот ответ полезен?
@maximilians4891 since you tried all kinds of different chargers, we are going to make the assumption that the charger is not the issue. In that case you want to consider a. the battery. Remember that a dead battery cannot hold or a take a charge. Check your battery connection. Here are the instructions for the battery.
Samsung Galaxy A32 5G Battery Replacement
After that, you want to check according to the flowchart
and here is where you will find the components to be checked.
The battery health is good, just discovered that it is not connecting to pc and it's only charging from it, and still slow
@maximilians4891 Can you try cleaning out the charging port gently with a non-metal object? Pocket lint can get into ports and prevent the data pins from making contact.
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 85
За всё время: 779
