The Nissan Sunny is an automobile built by the Japanese automaker Nissan from 1966 to 2006. In the early 1980s, the brand changed from Datsun to Nissan in line with other models by the company. Although production of the Sunny in Japan ended in 2006, the name remains in use in China and GCC countries for a rebadged version of the Nissan Almera.
Вопросов 14 Показать все
Why my nissan taking lot of fuel
Посмотреть содержание изображения:
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
There are many reasons why your car might be using more fuel than usual. Without additional context, here are a few things that might be contributing. Is there a check engine light on? Check the codes; some things can cause the engine to burn more fuel, like a bad o2 sensor, MAF sensor, fuel injectors, etc. When was the last time you had a tune-up? If your car is really overdue for a tune-up, that can cause the engine to burn more fuel.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ravnit будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 282
