Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Restore to factory settings without my forgotten password
How do I force my ipad mini into factory settings when I can't remember password
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Hello! If you try to power the iPad on while holding the home button it should boot into recovery mode, then using a computer you can restore it to factory settings. If you have find my ipad enabled you may run into issues if you dont' have access to the icloud account its logged into anymore, as apple devices are tied to this ID when that is enabled, and you wont be able to use it again without that. @aklyman58
Был ли этот ответ полезен?
Оценка 0
Plug the device into the computer, then press and hold the power button and the home button together at the same time. Once the tablet resets, let go of the power button while continuing to hold down the home button.
Оценка 0
Добавьте свой ответ
Aklyman58 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 96
